  2. Functional Verification Shared Code
  3. "block based" sparse memory
  • Subscribers 38
  • Views 7207
archive over 19 years ago
This is another sparse memory model with an interface similar to shr_ram.  It attempts to improve performance by reaching a compromise between a flat implementation (used for fully/mostly implemented memories) and a keyed list implementation (used for very sparsely implemented memories) by using dynamically sized blocks to represent implemented regions.  See the user guide and examples for details.
Originally posted in cdnusers.org by spadix
csco_blk_memory_version_1_0.tar.gz
    Is there something similar available in System Verilog also.
    If yes, could you pprovide a example
    Parag
    Originally posted in cdnusers.org by parag123
