  2. Functional Verification Shared Code
  3. Using the Forum
  • Subscribers 39
  • Views 20346
Using the Forum
archive over 20 years ago
Welcome to the Verification Shared Code forum, where you can attach e programs to help other users in using Verification products. For the benefit of others please include a brief summary of benefits of your e program.
This forum is not intended to be a substitute for Cadence customer support and/or documentation, but we do believe that it will be helpful and a way to tap into vast knowledge that exists in our user community. Of course, any software support, documentation and installation issues should also be directed to your preferred Cadence support channels.
File attachments must use one of the following file extensions:.doc, .pdf, .html .zip, .il,.jpg,and .gif. Size limit on the attachments is 750KB. If you have questions or need help with attachments, send an email to community_moderator@cndusers.org.  We are able to increase the file size restriction on a case  by case basis.
Administrator, cdnusers.org
Originally posted in cdnusers.org by Moderator
  • jessejames
    jessejames over 7 years ago
    I am new at using OrCAD and i am getting this error when i try to import a gerber file into PCB capture. I am getting an "art_param.txt" in the search path.
    please advise,,
