  2. Functional Verification Shared Code
  3. e code: Sample RapidIO eVC Shareware
  • Subscribers 38
  • Views 17287
archive over 20 years ago
This package is a simple example of a Serial RapidIO skeleton environment. It contains an environment object with a simple agent which contains a sequence driver and a bfm when ACTIVE. It is by no means a complete RapidIO environment. It is merely shareware and can be used as an example of how to create a sequence based approach to RapidIO protocol. To run a demo, please cd to the shr_srio directory and execute the command "demo.sh" at the prompt. A demo should run (no simulator attached) that will run basic sequences and then open up the sequences sent in a sequence window as well as open the eRM utility to browse the environment.
Author" Corey Goss updated 8/3/2004 8962 bytes
Originally posted in cdnusers.org by Administrator
shr_srio.tar.gz
  • srinicvc
    srinicvc over 16 years ago
      I tried downloading it (after logging in to the forum with valid UID & password), I get 500 KB file, but when trying to open the WinZIP complains it is corrupted/damaged. Does anyone have a better link please?
    Srini
    www.cvcblr.com
