  2. Functional Verification Shared Code
  3. Support floating point in e
  • Subscribers 39
  • Views 21061
archive over 20 years ago
This package include basic floating point support for e.  It consists of an e wrapper for c floating point library that needs to be compiled into Specman order to be used.  A makefile is provided to accomplish that.  This is useful for people who want to do operations with real numbers in e.
Originally posted in cdnusers.org by stellfox@cadence.com
vrst_snfp.zip
    archive over 19 years ago
    I'm getting segmentation faults when I try to use this package on a 64 bit platform (64 bit SUSE linux on x86-64). Have you observed this? It's pretty easy to create the seg fault case, here's some example code:
    import vrst_snfp;
    extend sys {
    run() is also {
    var fpfn : snfp_floating_point_function_s = new;
    fpfn.op1.set("0.0");
    fpfn.op2.set("0.1");
    fpfn.its_type= FADD;
    fpfn.do_fp();
    outf("%s",fpfn.res.to_str());
    The seg fault occurs on the outf, when Specman attempts to access the .res field of fpfn. Any help would be much appreciated!
    Originally posted in cdnusers.org by astortz
    This package was created in 2002 when 64-bit machines were not available. It is a shareware, so you can not get R&D support for it. However in Specman 6.1 there is support for floating point numbers (new data type real). The release is scheduled for mid-April, but if you are interested you can try out the beta release. For details, please get directly in touch with me (hannes@cadence.com)
    -hannes
    Originally posted in cdnusers.org by hannes
    I'm running 6.1.1, the manuals don't support [b]real [/b] but I tested it and it works!
    extend sys{
    foo : int;
    keep foo == 10101;
    bar : int;
    keep bar == 99;
    !foobar : real;
    run() is also {
    outf("foo %d/bar %d = %f\n", foo, bar, foo/bar);
    foobar = foo/bar;
    outf("foo %d/bar %d = %f\n", foo, bar, foobar);
    Running the test ...
    foo 10101/bar 99 = 102.000000
    foo 10101/bar 99 = 102.030303
    Originally posted in cdnusers.org by earthur
    I've written a small macro which implements coverage for the real data type. You can look at the example and have a look in the doc directory for details. Note that coverage of real type will be supported natively in SPMN6.2, however it does not support cross and transition coverage, which is supported by this macro.
    -hannes
    cdn_snams_util.tar.gz
