  2. Functional Verification
  3. Checking casting of an enumerated type
  • Subscribers 66
  • Views 13954
MaurizioCDN
MaurizioCDN over 17 years ago
In my e-code I am retrieving  a byte from a menory read and then I cast it into an enumerated type created by myself; however before doing that I would like to check the validity of byte ,i.e. if the byte maps to a valid entry in the enumerated type. Is there a command to check that and issue an error if it does not map?
Maurizio
  • ThinkVer
    ThinkVer over 17 years ago
    Interesting question. Is your enumerated range contiguous? if so you may be able to simply do something like this:
    if my_byte is in [FIRST_ENUM..LAST_ENUM] then { //do something };
    Does anyone know a better way?
  • ThinkVer
    There's another way which might be even better - the method all_values() will return a list of all possible scalar types. Here's an example:
    type ttt: [E1=3, E2=10];
    extend sys {
        run() is also {
            var x: byte = 3;
            if x.as_a(ttt) in all_values(ttt) then { out(" *** X IS IN WITHIN RANGE *** ") };
    Hope this works for you.
    Yaron
