  2. Functional Verification
  3. Help on using VPWL_F_RE_FOREVER
  • Subscribers 67
  • Views 15667
dominic0477
dominic0477 over 17 years ago
Hi fellow designers! I get this error message while using the VPWL_F_RE_FOREVER. ERROR -- Invalid Time (.STIMULUS) in file "ordino_stims.stl" Line 13 I've spent hours browsing the PSpice Manual but there is no detail about VPWL_F_RE_FOREVER that could help me figure out the problem. Your advice will be highly appreciated. Thank you!
  • oldmouldy
    oldmouldy over 17 years ago
    A VPWL_F_RE_FOREVER part is a for a VPWL_FILE that repeats forever. The first thing to check is that the file works as a VPWL_FILE and then work on the repeating. The "file" for a VPWL_FILE part is a tab delimited text file with two columns, time and value, the "time" must be monotomic (increasing), and both values can take any legal PSpice notation for value, including scientific or multiplier, 0,0 is assumed as the start if a 0 time value is not specified, linesr interpolation is used between the specified points inthe file. The "FILE" property of the part in the schematic takes the FULL PATH and FILE NAME for the referenced text file. (As in C:\MyDir\MyFile.txt)
    STL files created with the Stimulus editor are not valid sources for the VPWL_FILE parts, they are used with the VSTIM parts for voltage. (There are ISTIM parts for current sources) The PSpice Reference Manual describes Independent Voltage (and Current) Sources.
  • dominic0477
    Thanks a lot! It works now :)
  • Black Mamba
    Black Mamba over 12 years ago
    I want to generate a PWL signal,but I don't know how to set the VPWL_F_RE_FOREVER/Design Cache function.
    So who can teach me how to set function suite?
    I really want to know how to create a txt.file,and  internal document how to set the time and V-value.
    Thanks a lot.
