  2. Functional Verification
  3. Hierachical comparisson issues in LEC
  • Subscribers 66
  • Views 15784
Verplec
Verplec over 17 years ago
      I sucessfully completed a
   write hier_compare
   run hier_compare
 verification approach , however in the run log i see 2 primary warnings:
  // Warning: Module 'XXXXXXX' exists in Revised only. Skip it for hierarchical comparison
// Warning: Golden or Revised have modules with number of instances less than 50. Skip it for hierarchical comparison
//    (G) xxxxxxx
//    (R) xxxxxxx
I am wondering if any one be kind enough to help me , ridding of these warnings or a work around to inform LEC not to skip anything.
Thank you in advance.
Roy
    archive over 17 years ago
    Hello Roy, For the first message there may be some restructuring done.If it is a noneq then would definitely show up at the top level.As far as the second message is concerned modules which are skipped are merged onto the toplevel and then compared.So we can safely ignore these messages. --Vishnu
  • Verplec
     Hi Vishnu,
    Thank you for the prompt reply, for the first warning
    prior to  " write hier_compare " I have perform set naming rules
    set naming rule "_" -hier -both            // hierarchy separator char: Golden and Revised
    add ren rule r1 "_reg\[%d\]" "_reg_@1_0" -gold
    add ren rule r2 "_reg\[%d\]\[%d\]" "_reg_@1__@2_0" -gold
    add ren rule r3 "queue_table\[%d\]" "queue_table_@1_0" -gold
    add ren rule r4 "queue_table\[%d\]\[%d\]" "queue_table_@1__@2_0" -gold
     could those warning be the result of the renaming rules?
     as for your explanation of the second class of warning , how can I show , that those skipped modules are merged and still compared. I need to show proof basically , not that I don't trust you.
     one last question in this post  , I thought the write/run hier_compare routine black boxes sub modules, so how does a noneq in a submodule be detected at top level module?
    Thank you
    Roy
    Hello Roy, 1) Is the renaming rule cause of the problem ? a) If the renaming rule was a success , you would not seen the warning of a missing module on revised or golden. b) if the renaming rule failed then there is a possibility of you seeing the message.Have you tried the "test renaming rule" to check if it worked? 2) to show if the modules are really merged ? That is the core functionality and the warning message is the proof.One way of checking may be using gate manager or schematic to prove this. 3) black boxing ? there is a concept of dynamic hierarchical comparision where the non-eq module are un black boxed and included in the comaprision of the parent module.You may want to get the script reviewed by the expert support available by filing a ticket through sourcelink.cadence.com. Hope this helps. -- Vishnu
