  2. Functional Verification
  3. Integrating single vr_ad with multiple instance of AXI ...
  • Subscribers 65
  • Views 13658
Integrating single vr_ad with multiple instance of AXI eVCs
Kamal
Kamal over 17 years ago
Hi, I am trying to integrate the vr_ad (Cadence utility) into my environment. I have a situation that there are multiple instances of AXI which will try to access a single vr_ad. Please provide me with an example... Thanks, Skamal
  • Kamal
    I integrated vr_ad into axi using the code below
    extend sys{
      addr_map : vr_ad_map;
      reg_driver : vr_ad_sequence_ driver is instance;
      keep reg_driver.addr_ map == value(addr_map) ;
      keep soft reg_driver.default_ bfm_sd == axi_evc.active_ masters[0] .driver ;
      reg_file : REG1 vr_ad_reg_file;
      post_generate( ) is also {
     addr_map.add_ with_offset( 0x0070000, reg_file) ;
    extend vr_axi_master_ driver {
      rdata : list of vr_axi_memory_ entry;
      keep rdata.size() ==0;
      vr_ad_execute_ op(operation : vr_ad_operation) : list of byte @clock is {
      if operation is a REG vr_ad_operation (op) {
      var i : uint;
      var lod : list of vr_axi_data_ t;
      var rsize : vr_axi_transfer_ size_t;
      var bkind : vr_axi_burst_ kind_t;
      var write_response : vr_axi_response_ t;
      var read_data : list of vr_axi_memory_ entry;
      rsize = ilog2(op.reg. get_size( )).as_a(vr_ axi_transfer_ size_t);
      bkind = FIXED;
      if operation.direction == WRITE {
      // Write a single register
      lod.add(op.reg. read_reg_ val().as_ a(vr_axi_ data_t));
      write_response = sequence.write_ burst(op. address, 1, rsize, bkind, lod);
      } else {
      for {i=0;i<op.reg.get_size( );i+=1} {
      result.add(0x0) ;
      rdata = sequence.read_ burst(op. address, 1, rsize, bkind);
      for each (e) in rdata {
      result.add(e. data);
    // 3. Extending the monitor to update the register model.
    extend vr_axi_agent_ monitor {
      on write_burst_ ended {
      if (cur_write_transfer .p_burst. as_a(WRITE' direction vr_axi_monitor_ burst).resp == OKAY) {
      var current_data : list of byte = get_data_from_ transfer( cur_write_ transfer) ;
      if cur_write_transfer. address in [0x0070000.. 0x7FFFFF] then {
      sys.addr_map. update(cur_ write_transfer. address, current_data, {});
      out("vr_ad current write ADDRESS is ",cur_write_ transfer. address);
      out("vr_ad current write DATA is ",current_data) ;
      on read_burst_ended {
      if (cur_read_transfer. resp == OKAY) {
      var current_data : list of byte = get_data_from_ transfer( cur_read_ transfer) ;
      if cur_read_transfer. address in [0x0070000.. 0x7FFFFF] then {
     compute sys.addr_map. compare_and_ update(cur_ read_transfer. address, current_data) ;
      out("vr_ad current read ADDRESS is ",cur_read_transfer .address) ;
      out("vr_ad current read DATA is ",current_data) ;
      get_data_from_ transfer( c_trans: vr_axi_monitor_ transfer) : list of byte is {
      var num_of_bytes : uint = (1<<c_trans.p_burst. size.as_a( uint));
      for i from 0 to (num_of_bytes - 1) {
      result.add(c_ trans.data[ ((i+1) * 8) -1:i*8].as_a( byte));
    I am trying to write virtual sequence for the vr_ad  like this :
    sequence vr_ad_virtual_ sequence;
    extend vr_ad_virtual_ sequence_ driver {
     seq_drv : vr_ad_sequence_ driver;
      event clock is only @sys.any;
    extend sys {
      edriver1 : vr_ad_sequence_ driver is instance;
      virt_drv : vr_ad_virtual_ sequence_ driver is instance;
     keep virt_drv.seq_ drv == edriver1;
    extend MAIN vr_ad_sequence {
      keep count == 0;
    extend MAIN vr_ad_virtual_ sequence {
      !vr_ad_config : vr_ad_sequence;
      body()@driver. clock is only {
     do vr_ad_config keeping {
      .driver == driver.seq_drv;
    But after running the environment I am getting the following error:
    *** Error: Contradiction:
      A contradiction has occurred when generating vr_ad_sequence- @1892.(search_ from.get_ all_regs( ).all(.kind= =reg_kind) ) :
      Previous constraints reduced its range of possible values,
      then the following constraint contradicted these values:
      it is a vr_ad_reg (r) and r in* at line 43 in @vr_ad_predefined_ seq
      Reduced: vr_ad_sequence- @1892.(search_ from.get_ all_regs( ).all(.kind= =reg_kind) ) from [0x1..0xffffffff] items into [ items
      Using: == { vr_ad_map-@1 }
    For more details, open Generation Debugger
      *** Error: Error during tick command
    Can any one please figure out the error I am doing and why this error is occuring.
    S Kamal.
