  2. Functional Verification
  3. String concatenation
  • Replies 7
  • Subscribers 66
  • Views 20303
SpecMAN INFANT
SpecMAN INFANT over 16 years ago
My requirement is to create a list of names err_00_count; err_01_count and so on till err_99_count. In order to achieve this I used the append operator  as append("err_",x,"_count"). where x was a loop variable. But the result comes out as  err_0x<actual no.>_count. Is there any way in which the 0x can be eliminated?
  • StephenH
    StephenH over 16 years ago
    Try this:
    appendf("err_%02d_count", x);
  • SpecMAN INFANT
     Thanx Stephen, But I want to replace '%02d' with a variable : i.e.  '%xd' which is not possible
  • StephenH
    Have you read the manual to see the syntax of appendf()?
    If you want the number in hex, then modify my suggestion to use the %x print format instead of %d.
    The arguments for appendf() are exactly like the printf() function in C, so it should be pretty obvious how to adapt it for your needs...
  • SpecMAN INFANT
     Stephen, What I meant was I want to replace with a 02 with loop variable x or y .,say(e.g. with y )  err_%yd_cnt which is not possible....!!!!
  • StephenH
    Please don't keep saying it's not possible, you just need to understand what the C printf() format string means.
    A quick Google search or looking at a C text book will tell you all you need.
    In order to help you, I have written a small demo. Here is the Specman code:
    $ cat print_demo.e
    extend sys {
      run() is also {
        for x from 0 to 5 {
          out( appendf("err_%02d_count", x) );
    And here is the output from the demo code:
    $ specman -c "load print_demo ; test"
    Welcome to Specman Elite (08.20.003-s)  -  Linked on Thu Mar  5 17:31:56 2009
    Protected by U.S. Patents 6,141,630 ;6,182,258; 6,219,809; 6,347,388;
    6,487,704; 6,499,132; 6,502,232; 6,519,727; 6,530,054; 6,675,138; 6,684,359;
    6,687,662; 6,907,599; 6,918,076; 6,920,583; Other Patents Pending.
    Checking license ... OK
    Loading print_demo.e ...
    read...parse...update...patch...h code...code...clean...
    Doing setup ...
    Generating the test using seed 1...
    Starting the test ...
    Running the test ...
    err_00_count
    err_01_count
    err_02_count
    err_03_count
    err_04_count
    err_05_count
    No actual running requested.
    Checking the test ...
    Checking is complete - 0 DUT errors, 0 DUT warnings.
  • SpecMAN INFANT
     ThanxStephen.. misinterpretation from my side.....
    Also, I saved the above appendf o/p to a variable(loop_str) (of type string ). My requirement was to access an hdl signals with the name err_<number>_count put inside the loop. But when I try to access using the stored variable(loop_str); error meessage pops up saying hdl signal loop_str doesn't exist in the hdl sig def.   i.e. it doesn't take the replacement for loop_str. Is there any way in which this can be done?
  • StephenH
    I see...
    If your ports are declared as a list, you're in luck, but if you copied & pasted 100 instances of the port, you're pretty much stuck.
    Loop example:
    err_count[100] : list of in simple_port of bit is instance;
    keep for each in err_count { it.hdl_path() == appendf("err_%02d_count", index); };
    That should give you a feel for what to try or look up in the docs :-)
    Good luck!
