  2. Functional Verification
  3. irun (ncsim) without waveform
  • Replies 8
  • Subscribers 66
  • Views 18440
sorel789
sorel789 over 16 years ago
I need to run a test without waveform. I'm using irun (ncsim). Code is written in systemverilog (OVM). Each time I run the test, the waves.shm dir is created with 2 files : 1 dsn and 1 trn. I don't need them, I just want to run without gui and without waveform.
my command : irun -v200x -ovm -incdir my_dir -nowarn PMBDVX +OVM_TESTNAME=test_name tb_top.sv rtl.vhd
  • Mickey
    Mickey over 16 years ago
    There must be a system task in your verilog source code that is causing the database to be created.  Look for a $shm_ tasks in tb_top.sv and either comment them out or surround them with conditional compiler directives.
    Best regards,
    Mickey
  • sorel789
     there is no shm task or other task in my code to do that.  maybe in ovm_test, ovm_env  ... but I didn't find anything :(
  • tpylant
    tpylant over 16 years ago
    OVM has automatic transaction recording that will generate transaction waveforms. Search for "enable_recording", "begin_tr", or "end_tr" to see if your code is calling any of those routines.
    Tim
  • sorel789
     Í've removed all enable_recording, begin_tr and end_tr tasks .. and waves.shm (trn, dsn) is still created.
    2 minutes later :   I have in my ovm_test::build - set_config_int( "*", "recording_detail", OVM_FULL);
    I've changed OVM_FULL with OVM_NONE and no waves.shm was created.
    Thanks !
  • Mickey
    Thanks for your patience as we try to narrow where in the code the instruction for dumping waveforms is located.
    I noticed that you are using a -incdir to include various files out of the directory named my_dir.  Can you grep for "shm_" in all of the files of that directory (unix>  grep shm_  my_dir/*).
    as another option try doing a decompile of the snapshot as follows:
    1)  find the name of the snapshot (ncls -snapshot)
    2)  decompile the snapshot (ncdc -origfiles <snapshot name>)
    3)  cd into the created ncdc directory and grep for shm_ in all of the files that were created.
    if the above doesn't work, let me know, I have some other ideas that may help.
    Best regards,
    Mickey
  • Mickey
    another option to find the problem code is to temporarily rename the shared object that resolves the shm_ tasks.  Be aware that you will affect other users ability to create a waveform dump while you make this change.  Consequently I would do the following after having exhausted all other attempts to find the code with the tasks.
    1)  cd into <IUS_install>/tools/lib
    2)  rename the file named libdwapi.so to libdwapi.so.bak
    3)  cd back to your run directory and rerun the simulation.
    when the shm_ tasks are encountered you will get messages similar to the following, indicating the line and file where the task is found:
    Warning!  $shm_open - unable to open database file (check installation)
                File: ./mux_test_random.sv, line = 16, pos = 10
               Scope: mux_test
                Time: 0 FS + 0
    4)  After discovering where the tasks exist in the code be sure to go back to the installation directory and mv libdwapi.so.bak back to libdwapi.so
    Hope that helps.
    Mickey
  • Mickey
    My Bad...  I didn't completely read your last post until now.  it's good that you have found the source of the database creation.
    Mickey
  • Games people
    Games people over 16 years ago
    True,OVM has automatic transaction recording that will generate transaction waveforms. Search for "enable_recording", "begin_tr", or "end_tr" to see if your code .
    Tim
