  2. Functional Verification
  3. Issue while using already compiled libraries in IUS-8.2
  • Subscribers 67
  • Views 14969
Shunty
Shunty over 16 years ago
Hi All,
I am stucked at one situation while using IUS-8.2. I have some compiled libraries of vhdl in one INCA_libs folder.
Now In my System Verilog environment, I want to use those already compiled libraries of VHDL.
So I want to use the  INCA_libs folder. what i did is,
While running my environment using irun, i used -cdslib switch to use those libraries.
irun -cdslib <PATH_TO_DESIGN_LIB_CDS_LIB>  -f <VE.f>
Where,  PATH_TO_DESIGN_LIB_CDS_LIB is a cds.lib file of the already compiled INCA_libs of design.
VE.f contains my Verification Environment related file.
Is this a correct way to do this? If not then please suggest correct one.
There is one strange problem occurs while using this command,
When the packages  are imported inside the VE files shows this error,
import imp_1::*;
ncvlog: *E,MULTPK (test.sv,7|11): Multiple (2) packages named "imp_1" were found in the searched libraries:
                -> found verilog_package worklib.imp_1:sv (VST)
                -> found verilog_package worklib.imp_1:sv (VST).
import imp_1::*;
To debug this,
When I opened cds.lib of my design's INCA_libs, last 2 statements were something like this,
DEFINE worklib worklib
DEFINE Mux worklib
When I removed the last statement which was for mapping purpose, The above error of importing the package got resolved.
But I did not get the successful loading of libraries because simulator gave me an error when I created an instace of  Mux entity.
Anyone has any idea about this?
-Shunty
  • asedehi99
    asedehi99 over 16 years ago
    Did you ever figue this out?
  • laohan
    laohan over 14 years ago
    I got the same problem as "multiple pakage found in the searched libraries" as well.
    This happened when I changed the extension of package file. Simply I just change defs.pkg into defs.sv
    This problem bothered me for a day, and it finally solved by deleting the directory called "INCA_libs" in my simulate directory.
    So I assume that the multiple file found problem might be about the complied files. Probably the old compiled file and the new compiled file exist in the same time, that's why simulator sees 2 or more package.
    But your situation is much more tough than mine, you need to keep the already compiled files. But I think there might be some way to handle the files, maybe backup the files you wanted, delete the rest and run, then put backup into the new created directory and see how it goes.
    I don't know, just using systemverilog for less a year. Hope this idear helps.
    Good luck
  • TAM1
    TAM1 over 14 years ago
    laohan,
    Explaining the actions of the library system in IUS can be pretty complex. It has to be all things to all people, so there's a lot of ins-and-outs that are probably too much for a posting on a web forum. That being said however, he's why changing your filename ended up with a duplicate package.
    IUS stores its compiled objects with 3 attributes that identify it, library, objectname and view. By default, irun takes the view name from the suffix of the source file it is compiling. So a package called mypackage from a file mypackagefile.pkg would be compiled into work.mypackage:pkg. If you change the filename to mypackagefile.sv, you get a new object added to the database, work.mypackage:sv. You can control this explicitly by using the -view option on irun, but as you've found it is easier to remove the INCA_libs and start again.
  • TAM1
    Shunty,
    As far as your issue goes... I believe you should have seen error or warning messages about mapping multiple logical library names to a single physical library. So the tool doesn't like it when you do that.
    You said "But I did not get the successful loading of libraries because simulator gave me an error when I created an instace of  Mux entity." We'd need to know more about the error that you saw to comment on how to fix it.
  • laohan
    very helpful, very helpful.
    It is quite a improvement for my understanding of using SystemVerilog when I could talk with a pro like this.
    Thank you very much :)
