  2. Functional Verification
  3. compiling $damem_* tasks with irun
  • Subscribers 66
  • Views 2529
mmk23
mmk23 over 16 years ago
Hi All,
                I'm trying to compile a module which has $damem_* tasks in it. I use irun to compile in ncvlog  but I'm getting
  ncelab: *W,MISSYST ( fielname.v,264|21): Unrecognized system task or function (did not match built-in or user-defined names) [2.7.4(IEEE Std 1364-2001)].
Please let me know about  pli that needs to be run to avoid this Warning message.
mmk
  • Shalom B
    Shalom B over 16 years ago
    The damem directory can be found at tools/examples/pli/damem/.
     Shalom
  • mmk23
    I've run with the LOADPLI = -loadpli1 $(PWD)/../../../../../src/damem_LDV34/src/libdamem.so:bstrap , but I got the following msg, SYSTEM ERROR: ACC LOADFB Failed to find requested bootstrap routine bstrap in library ../src/damem_LDV34/obj-lnx86/libdamem.so Could anyone please tell me the steps to resolve this? Thanks, mmk
  • Mickey
    Mickey over 16 years ago
    Hi MMK, I don't believe the version of damem that's included in the LDV install includes a bootstrap function, which is why you got the LOADFB error. Here's what you need to do 1) If you haven't done so already, execute the Makefile included in the src directory. You may want to make a copy of the damem directory somewhere on your network and execute the make in the copy. Your choice. A result of the make will be a file named libpli.so and it will be placed in the directory from which the make was executed 2) Next add the DIRECTORY containing the libpli.so to your LD_LIBRARY_PATH env variable. This will allow the tool to automatically load the dynamic library. The only drawback here is if you already have a libpli.so file being added in such a manner. Make sure you prepend the LD_LIBRARY_PATH with the directory containing the libpli.so for damem. 3) No need for a -loadpli1 command line option. By prepending the directory to LD_LIBRARY_PATH the tool will automatically load the libpli.so file. So from here run the simulation as you were doing previously. Best regards, Mickey
  • mmk23
    Thanks Mickey, I've resolved it. The boot strap function name was set incorrectly earlier in the make file. It should be damem_bootstrap as in the C file. Thanks, mmk
