  2. Functional Verification
  3. Using struct and Union
  • Subscribers 65
  • Views 13979
hipooja
hipooja over 16 years ago
I have used class to model different parts of VE ranging from the data structure to drivers ,generator , monitor ...Class is a collection
of different data types so is a struct and a union.The difference i know is that union occupies memory equal to its largest data element unlike a struct or a class and secondly a struct can contain a union ,even a class can have a nested class object.
 My questions is ,where do we use struct and union.Have you used them in modelling data or any other element of the VE and why?
How do i differentiate as to where should i be using a class/struct/union.
Pooja Vaishnav
  • tpylant
    tpylant over 16 years ago
    A struct is an array of data objects. it can be packed or unpacked but only packed structs can be used in synthesizable code. The following is a packed struct because it consists of only literals.
    struct packed {
      logic [15:0] addr;
      logic [31:0] data;
      bit          parity;
    } frame;
    A union allows the specification of multiple representations for the same data element.
    union {
      int        i;
      reg [31:0] r;
    } data;
    The data object holds a single 32-bit value but can have it represented as a 2-state integer or a 32-bit 4-state reg depending on whether you access it use the “I” or “r” type.
    Now you can put these two constructs together as so:
    struct {
      logic [15:0] addr;
      union {
        int        i;
        reg [31:0] r;
      } data;
      bit          parity;
    } frame;
    Tim
