  2. Functional Verification
  3. Passing arguments from irun command line to top module
  • Replies 7
  • Subscribers 67
  • Views 24097
abhingp01
abhingp01 over 15 years ago
 I need to pass certain parameters to my top verilog module from irun command line.
Some thing like:
irun ------- argr1,agr2
Is this possible ?
Kindly give a small example if possible.
Thanking  you in advance.
Abhishek
  • TAM1
    TAM1 over 15 years ago
    You can use the built-in $test$plusargs function to read special purpose options from the command line.
     I found the following link using google which has some examples showing how that function is used.
     http://www.project-veripage.com/plusarg.php
  • Mickey
    Mickey over 15 years ago
    You can use -defparam. -DEFparam parameter_pathname=value, eg. -defparam top.dut.u1.param4=8 .... Best regards, Mickey
  • abhingp01
     Thanks a lot Tam1 and Mickey
  • albas
    albas over 8 years ago
    How would you pass an enum to the defparam? I get weird numbers in the parameter.
    Thanks in advance,
    Al
  • tpylant
    tpylant over 8 years ago
    Is this what you're referring to:
    typedef enum bit {NO, YES} bool_t;
    module test;
    dut dut ();
    defparam dut.p = NO;
    endmodule
    module dut ();
    parameter bool_t p = YES;
    initial $display ("p is %n", p);
    endmodule
    Tim
  • albas
    Uhm, interesting enough the example you are using is working correctly (tried on edaplayground.com), but this one does not work correctly:
    module test;
    dut dut ();
    endmodule
    module dut ();
    endmodule
    the -defparam options passed to incisive does not overwrite the locally defined parameter. Moreover I have the following situation www.edaplayground.com/.../ufn where the outcoming output of the parameter value is completely wrong.
    What is the main difference between these examples?
    Thanks for your support,
    Al
  • tpylant
    It looks like ENUMs are not getting taken from command line. If I pass the numerical equivalence (NO=0, YES=1), then it works as expected:
    irun test.sv -defparam test.dut.p=0
    p is NO
    Tim
