  2. Functional Verification
  3. DPI-C Simulation error
  • Subscribers 69
  • Views 6592
Miguel Caetano
Miguel Caetano over 15 years ago
Hello to all,
 I'm new at SystemVerilog and i'm trying to create a way to use C code.  However, when i run the ncsim i obtain these following messages:
"ncsim: *F,NOLWSV: Unable to load the default library libdpi."
"OSDLERROR: ./libdpi.so: cannot open shared object file: No such file or directory or file is not valid ELFCLASS32 library.."
The c-program is a very simple one:
#include "svdpi.h"
void reportc()
printf("Hello World from C! ");
and the systemverilog code is:
 program main();
//string str;
import "DPI-C" reportc=task reportc();
initial
begin
  reportc();
end
endprogram
 Thanks for your help
Best Regards
Miguel Caetano
  • Pushpa P
    Pushpa P over 15 years ago
    Hi Miguel, I think the problem is that the libdpi.so file is not created. I ran the program and found no error. These are the commands that I used : >ncvlog -sv hello.sv >ncelab main >gcc -fPIC -shared -o libdpi.so hello.c -I /tools/cadence/Incisive92/IUS92/tools/inca/include where ( /tools/cadence/Incisive92/IUS92) is the installation directory >ncsim main
  • basa
    basa over 14 years ago
    I tried with the same .sv with c function calling, my sv file name is sv_c_dpi.sv  and c file name as c_sv.c
    I gave the command as
    step 1: ncvlog -sv sv_c_dpi.sv  ---- compiling successfully
    step 2: ncelab main               --- success
    step 3: gcc -fPIC -shared -o libdpi.so c_sv.c (In c file i have included the complete path of svdpi.h)    ---- success  libdpi.so file is created.
    step4: ncsim main           --- Error  (cannot open shared object file : No such file or directory or file is not valid ELFCLASS32 library)
             My both .sv and .c files are contains same data as above said.  Can you give me more insight on how to solve this issue.
             Thanks in Advance.
  • Vishnugupt
    Vishnugupt over 14 years ago
     Check with this
    step 3: gcc -m32 -fPIC -shared -o libdpi.so c_sv.c (In c file i have included the complete path of svdpi.h)
     Hope this helps!
    Vishnu
