  2. Functional Verification
  3. Referencing a VHDL signal from a Verilog Module
  • Subscribers 66
  • Views 14431
ashfaqh
ashfaqh over 15 years ago
 Hello:
 I am using  ncsim   09.20-s016.
 I have a VHDL DUT.  The testbench top level is VHDL.  But, I have a few Verilog modules in the testbench.
From one of the Verilog modules, I want to access (monitor) a signal inside the DUT (VHDL).
For example,
if (top.level_1.level_2.sigout_1 == 1'b1)
            $display("Posedge received at time: %d", $time) ;
 I get the following error:
 ncelab: *E,CUVHNF (...): Hierarchical name component lookup failed at 'top'.
1.  Is it not possible to monitor a signal  inside a VHDL scope from a Verilog module?
Thanks.
  • tpylant
    tpylant over 15 years ago
    You can use the “nc_mirror” command.
    Tim
