  2. Functional Verification
  3. General question/problem with Cadence
  • Subscribers 66
  • Views 946
Robak
Robak over 15 years ago
Hello:)
I`ve got a two questions, for now;) The first one, is there a possibility to set up the Allegro Design Entry CIS that after the save file the undo function will be avalible? And the second one is more annoying, when I mark an element and enter "edit properities", and do the same thing with another element without closing the properity window, the content doesnt refresh:( So, if I open edit properities window then close it and open again everything is ok, but it is very annoying to rember closing the window again and again;)
Thanks in advance
Robert Malczyk
  • oldmouldy
    oldmouldy over 15 years ago
    The Undo / Redo data gets cleared on Save, there is no way to toggle this.
    Try "Apply" on the Property Editor, basically there is just one tab for the property editor. You might want to get this raised as an enhancement, like "auto-apply settings when another property editor session opens"
  • Robak
     Unfortuneatly solution with apply doesnt work:(
