  2. Functional Verification
  3. vr_ad_reg_file multiple instance
  • Replies 19
  • Subscribers 100
  • Views 35573
Ravisinha
Ravisinha over 15 years ago
Hello All,
I have a situation where i want to implement 8 instance of some particular reg_file which all have many reg_def and reg_fld.
For example :
I have 8 instance of one DUT module (TEST0, TEST1,TEST2... TEST8), since its all are the instance so all the instance will have the sets of registers.. so to implement reg for one instance i can write code like..
extend vr_ad_reg_file_kind : [TEST0];
extend TEST0 vr_ad_reg_file {
keep size == 256;
reg_def EX_REG_TX_DATA TEST0 8’h00 {
// name : type : mask : reset value
reg_fld data : uint(bits:8) : RW : 0;
But now the issue is inside 1 instance i have around 256 registers, and i need to implement for all the 8 instance.... so can anyone suggest me how we can make instance for vr_ad_reg_file, otherwise i have to write same code for all the 8 instance.
  • hannah89
    hannah89 over 3 years ago
    Thank you for the very interesting post. concrete contractors brooklyn ny
  • Mike476
    Mike476 over 3 years ago in reply to Agentred
    You can go on Attrape Reve Shop if you want to buy a dreamcatcher.
  • leenapearl
    leenapearl over 3 years ago
    Thanks for your post. I’ve been thinking about writing a very comparable post over the last couple of weeks, I’ll probably keep it short and sweet and link to this instead if thats cool. Thanks. wealth management
  • Gurugram Escorts
    Gurugram Escorts over 3 years ago
    Gurgaon Escorts lady is highly educated and friendly behavior for our client. if you would like some hot experience with our escorts just check our site gallery page also as you'll contact us by phone. We are a luxury escort service provider in Gurgaon and every one solution at one place. Gurugram Escort, Aerocity Escorts, Delhi Russian Escorts
  • refreshrate
    refreshrate over 3 years ago
    Nice post. Keep it up. The monitor alone determines the refresh rate, not the processor or graphics card. It varies from another similar phrase, frame rate, in this regard. A machine that can produce a high frame rate in addition to a monitor with a high refresh rate is required for maximum performance. You could not receive the full benefits if either is poor, which could affect the display's quality. There are various Online refresh rate test tools available to check the monitor's refresh rate.
  • Printerexpert
    Printerexpert over 3 years ago
    Numerous instances of the same register type are present in many of the devices we evaluate. These registers are instantiated inside the design using a standard structure. In our testing, we need to have access to each of them.
    Jenson| https://www.southernimagingcopiers.com/
  • Kashmir Tourism
    Kashmir Tourism over 3 years ago in reply to Printerexpert
    Explore Kashmir, the true paradise on earth with our beautifully crafted Kashmir Tour Packages. The best Honeymoon tour in Kashmir is our USP. Enjoy your holidays in Kashmir with us.
  • Kashmir Tourism
    Kashmir Tourism over 3 years ago in reply to Kashmir Tourism
    I appreciate this article because it is full of the information I seek. I may visit the website regularly to update the latest information Pilgrimage Tourism
  • chennaiescort2021
    chennaiescort2021 over 3 years ago
    Day with the maximum stunning Chennai Escorts angels and invest your leisure activity instances recommending personal issues. We have the first-rate name more youthful girls withinside the city, organized to mix with you.
