  2. Functional Verification
  3. ncelab SDF warning
  • Subscribers 67
  • Views 17059
ncelab SDF warning
jpvSoccer
jpvSoccer over 15 years ago
What are the implications of the following message:
Ncverilog.log
ncelab: *W,SDFRDE: Read error for default code, skipping annotation of wst.sdf.X.
JPV
  • TAM1
    TAM1 over 15 years ago
    The times I've seen this error in the past have all been due to a corrupted SDF file. The solution has been to delete the .X file and get the process to start from the original text .sdf file again.
  • Design fortest
    Design fortest over 14 years ago
    i'm encountring this SDFRDE w , while doing my sdf simulations
    a already tried to delete the binary generated and start my simulation low from the begenning but i'm still getting the same error
    can you help please ?
  • TAM1
    TAM1 over 14 years ago
    Can you show us some of your log file?
    If that doesn't help, I think we'll have to refer you to Cadence customer support. :-(
  • jpvSoccer
    jpvSoccer over 14 years ago
    Hi thanks for the email. I no longer need help on the problem. :)
  • Design fortest
    Caching library 'workn' ....... Done ncelab: *W,FLFNOF: No SDF file specified, but annotation parameters were present, in SDF annotation command file SDF/WC/WC_CMD_FILE, line 6.
     Annotating SDF timing data: Compiled SDF file: SDF/WC/periph3_top_w.sdf.X Log file: ./log/ncelab_periph3_top_WC_annotate.log Backannotation scope: periph3_top_test.dut
    Configuration file: MTM control: MAXIMUM
    Scale factors: 1:1:1
    Scale type:
    ncelab: *W,SDFRDE: Read error for default code, skipping annotation of SDF/WC/periph3_top_w.sdf.X. ncelab: *W,SDFRDE: Read error for default code, skipping annotation of SDF/WC/periph3_top_w.sdf.X. Annotation completed with 0 Errors and 2 Warnings
    I already created a new directory with new .X sdf and netlist compilation. but I still have the same issue.
    can you help me please ?
    tool version: 08.20-s009
    BR
