  2. Functional Verification
  3. Part-Select of an Array in SystemVerilog ... Not supported...
  • Subscribers 66
  • Views 23095
Part-Select of an Array in SystemVerilog ... Not supported by Incisive ?
Almendrico
Almendrico over 15 years ago
Hi all,
I am trying to do something very simple with SystemVerilog
I have an 2-dimensional array defined as
typedef logic [3:0] SR8x4 [0:7];
and I just want to do a shift operation between the unpacked elements, i.e:
SR8x4[1:7] <= SR8x4[0:6];
However, I am getting the following errors:
ncvlog: *E,NOPSOM (ShiftRegister.sv,27|14): Part-select or indexed part-select cannot be applied to memory [4.2.2(IEEE)].
ncvlog: *E,NOPSOM (ShiftRegister.sv,27|28): Part-select or indexed part-select cannot be applied to memory [4.2.2(IEEE)].
        module worklib.ShiftRegister:sv
                errors: 2, warnings: 0
I believe the instruction is correct, so I think this SystemVerilog syntax is not supported by the tool ... I am using incisive 9.20
  • Shalom B
    Shalom B over 15 years ago
    Correct, this is not yet implemented in Incisive 9.2.
    It is scheduled for sometime in 10.2
     Shalom
  • tpylant
    tpylant over 15 years ago
    Here is a workaround until it is supported:
    module test;
      logic [3:0] arr [0:7] = '{0,1,2,3,4,5,6,7};
      initial begin
        $write("Pre");
        foreach (arr[i])
          $write(arr[i]);
        $write("\n");
        for (int l=1; <3; l++) begin
          foreach (arr[i])
            arr[i+1] <= arr[i];
          $write("%0d: ", l);
          foreach (arr[i])
            $write(arr[i]);
          $write("\n");
        end
      end
    endmodule
    Tim
  • Almendrico
     Thank you guys for the answers
