  2. Functional Verification
  3. iff on coverpoint block effecting another coverpoint with...
  • Subscribers 66
  • Views 17849
iff on coverpoint block effecting another coverpoint with transition in the same group
dambui
dambui over 14 years ago
I have a coverage group defined as below:
   covergroup ready2 @ (negedge clk);
      ready : coverpoint dataReady iff ! enable {
         bins is2 = {2};
         bins is1 = {1};
      ready2 : coverpoint dataReady iff enable {
         bins is2 = {2};
         bins is1 = {1};
      ready_trans : coverpoint dataReady iff enable {
         bins two2one = (2=>1);
         bins one2two = (1=>2);
I did not get any coverage on ready_trans
However, if I put 'iff' on bins, then everything works as expected:
   covergroup ready @ (negedge clk);
      ready : coverpoint dataReady {
         bins is2 = {2} iff !enable;
         bins is1 = {1} iff !enable;
         bins is2 = {2};
         bins is1 = {1};
   endgroup // ready
Unless my understanding of 'iff' usage is not correct, I do not see how the 2 cases are different.
This is compiled and run with 'irun' version 08.20-s012.
Any  helps or tips would be appreciated.
Dam
  • Shalom B
    Shalom B over 14 years ago
     Before anything else, you should probably try to run with the newest version of Incisive and see whether it still occurs.
    Shalom Bresticker
