  2. Functional Verification
  3. Ncverilog: Is there a predefined `define containing IUS...
  • Subscribers 65
  • Views 2417
Ncverilog: Is there a predefined `define containing IUS version number/string?
cubicle82
cubicle82 over 14 years ago
In C/C++ compilers, there are predefined macros which contain a version number/string ( example: __STDC_VERSION__ )  This enables source-code to enforce minimum version-checks (in some cases.)
Is there something similar irun, so my Systemveirlog-source files can check for a minimum version of IUS?
  • StephenH
    StephenH over 14 years ago
    Unfortunately Verilog doesn't support conditional expressions, so there's no clean way to do this. For example the following would be nice, but Verilog won't let you do it:
    `if IUS_VERSION > 9.2
      `if IUS_PATCH > 25
    The only alternative would be to create a naming convention for defines, like:
    `define IUS_VERSION_09_20
    `define IUS_VERSION_09_20_OR_LATER
    etc. The problem then is that you get an ever-growing list of defines, which is not great.
    Also, Verilog has no way to abort the compilation, e.g. you cannot do anything like:
    `ifndef IUS_VERSION_09_20_025_OR_LATER
      `error "Upgrade your IUS version to use this code"
    Sorry to disappoint you!
  • Shalom B
    Shalom B over 14 years ago
    SystemVerilog does have elaboration-time system tasks.
    An example from the LRM is
    module test #(N = 1) (input [N-1:0] in, output [N-1:0] out);
    if ((N < 1) || (N > 8)) // conditional generate construct
    $error("Parameter N has an invalid value of %0d", N);
    assign out = in;
    endmodule
    Shalom
  • StephenH
    Hi Shalom.
    Thanks for pointing that out. Indeed, this is a useful construct for checking design parameters are valid.
    It does not however help with the parsing / compilation phase, as the user might want to abort the parsing, or substitute different code depending on the tool version. Reasons to abort the parsing: if you're an IP provider and you know your code required IUS version 9.2.30 as a minimum, else ncvlog will generate misleading errors.
    I've seen many customers writing code like `idfef TOOL_BUG_1 ... `else ... `endif. This applies to all the major vendors by the way, not just IUS ;-)
    These things can't be handled at elaboration time... I'm really sorry we can't offer a positive answer here, rather than just saying why it won't work. We did discuss whether to ignore the LRM and add some kind of syntax to do conditional `if expressions and to abort parsin, but it's hard to justify the risk of breaking existing user code for the benefit it gives (not to mention the cost).
    Still, if enough people request such a feature (through the formal support channel) then anything can be considered...
