  2. Functional Verification
  3. Expression coverage understanding
  • Subscribers 66
  • Views 18198
Prachi1
Prachi1 over 14 years ago
Hi, I am running and analysing expression coverage. There I see that there are some expression with '!' or '~' (logical or bit negate), I do not understand how iccr evaluates it. e.g. diffxy = (~(x-y)) + 1'b1; index hit ---------------------------- 2 0 0 Here value of expression 1 is '0', is it value of x-y or (~(x-y). x is 16 bit vector. I tried all the possible values of x and y but I am not able to hit this condition. can some highlight the issue? Regards, Prachi
  • TAM1
    TAM1 over 14 years ago
    We don't really know enough to completely answer your question. So I'll make a couple of general comments. By default, iccr scores each term in an expression as if it could take on 2 possible values, 0 or non-zero. So even though the term (~(x-y)) might have 16 bits, unless you say otherwise, the report will only look for a time where it is zero and a time where it is non-zero.
    I plugged it into a small testcase. When x & y were both equal, I hit the 0 term and when they differed, I hit the 1 term.
    Line    Coverage         Expression description
    6 100% (2/2)         assign diffxy = (~(x-y)) + 1'b1;
                ( ~(x - y) ) + 1'b1
                 <---1--->
                  hit | <1>
                    1 |  1
                    1 |  0
    In your simulation, does 'x' ever equal 'y'? If so, you should hit the 0 term for expression 1.
  • Prachi1
     Thanks TAM1,
    This was really very helpful to me. In my code, x was set equal to y, but before the assignment for diffxy I had the condition if(x<y). so I was not able to hit this term.
    One more query I have. For the following expression
    temp2 = ~(temp1 - 1'b1);
      I am getting the expression coverage for uncovered item as:
         ~(temp1 - 1'b1)
         <-------1---------->
                  hit | <1>
                    0 |  0
    What values should I generate of temp1 which will allow me to hit the expression such that entire assignment value is 0.
    Prachi
