  2. Functional Verification
  3. need urgent help on vplan
  • Subscribers 66
  • Views 15706
buddi
buddi over 14 years ago
Hi
i am new to Enterprise manager tool. I am using Cadence AHB protocal
I created vplan for my environment coverage.
My design dont support SPLIT and RETRY responses for AHB protocal.
How i can ignore these (SPLIT and RETRY) responses from vplan document.
For example .
transfer_response cover item its showing only 50% covered(OKAY and ERROR coverd).
The other responses are not supported in my design. show i want to remove these from my coverage.
can you please help me
  • pcarzola
    pcarzola over 14 years ago
    There is the concept of a buckets filter which can be specified within the vPlan. EP makes it fairly easy to attach a filter to the item. See the help docs for details. There is an EP quickstart that will help you. You can also specify a buckets filter from the EMGR vPlan tree (right mouse menu) as a refinement. In this case the filter will be stored in a refinement file.
  • buddi
    Hi
    i am trying to remove specific parameters (RETRY and SPLIT) from vplan but i am getting following error
    can you please tell me why this error was coming and what is the meaning for this error.
    "No parameter values defined in the current plan. Right click the vPlan and do 'Create a parameter...'"
  • buddi
    i checked the help documetns for vplan.
    I am trying to filter some parameters (like RETRY, SPLIT) from vplan but i am getting the following error.can you please tell me why this error is coming.
  • pcarzola
    My guess is that somehow the parameters are missing from the top of the plan. You can't use the Parameter field until you have parameters defined at the top of the plan. To create parameters, click on the plan name with the right mouse button. in the menu you will see an option at the bottom to create parameters. Add Retry and Split again.
  • buddi
    i created filter for RETRY and SPLIT. but while loading emanager i am getting following error
    On-the-fly GC, current size is 2661967796 bytes (including 2951164 known free)
    Done - total size of reachable data is 137774308 bytes (plus 2527034896 free).
    On-the-fly GC, current size is 3649543080 bytes (including 990364976 known free)
    Done - total size of reachable data is 157629328 bytes (plus 3493691104 free).
    **** Fatal error - leaving vManager:
    Out of memory
    vManager failed: Unexpected error
    what is this error means? how i can set memory size
  • pcarzola
    Hello, I would recommend that you go to http://support.cadence.com and filing a ticket so that you get some good and detailed guidance on what you can do here to help with the memory issue.
