  2. Functional Verification
  3. FSM transactions are not extraced in ICCR tool(vmanager...
  • Subscribers 66
  • Views 2192
FSM transactions are not extraced in ICCR tool(vmanager)
buddi
buddi over 14 years ago
hi
i am unable to view FSM transactions in ICCR tool.
and observed the follwoing error in my log
ncelab: *W,COVFHT: FSM hold transitions (transitions to the current state) are not extracted for any FSM in default mode.
Enabling instrumentation for coverage types: block expression FSM toggle functional
what is the command need to extract FSM transactions should be used in irun
2)
how i can remove this warning
ncelab: *W,COVDCL: By default coverage is scored only for Verilog logical operators (|| and &&) and VHDL logical operators (OR, AND, NOR, and NAND), and is scored only in condition expressions. To score coverage for other operators, and for expressions in assignment statements, use the "set_expr_scoring -all" coverage configuration command at elaboration
  • buddi
    Can you please give any input for this warning *W,COVFHT.
    I am waiting for response or please tell me if any help documets are avialable
  • tpylant
    tpylant over 14 years ago
    The ‘nchelp ncelab COVFHT’ command returns the following information:
    ncelab/covfht =
            To extract FSM hold transitions, specify the "set_fsm_scoring
            -hold_transition" command in the coverage configuration file, and then
            pass it to ncelab using the "-COVFILE" command-line option. Scoring
            hold transitions might have a performance impact.
    Tim
