  2. Functional Verification
  3. ncsim TCL stop -object
  • Subscribers 66
  • Views 1904
zvika23
zvika23 over 14 years ago
hi again tcl command stop -object{#signal} is it valid to use on signals or buses?
  • TAM1
    TAM1 over 14 years ago
    The expected syntax is:
     stop -object signal_name
    "signal_name" can be a single bit or a vector. Any change to the value on that object will trigger the stop point. Don't use any braces or # operator to modify the name. Simply put it on the command line.
    The expression #signal_name returns the value of the signal called "signal_name" at the present time. So, to the TCL parser, it looks as if you are trying to put a stop on a binary constant which won't work.
