  2. Functional Verification
  3. Memory Content Viewer in Simvision
  • Subscribers 66
  • Views 22678
PAULKI
PAULKI over 14 years ago
Hi techies,
I'm using NCSim (09.20-s025). I need to view the memory contents which is pre-loaded in the GUI Simulation. Do we have any sub tool in NCSim to view the memory contents?
Here are my queries:-
1. Memory Content Viewer in Simvision
2. Memory Preload command in GUI for NCSIM
-paulki
  • Mickey
    Mickey over 14 years ago
    Hi Paul,
    To dump the content of memories in the waveform database...
    if you are using tcl probe commands, add -memories to the probe command, eg.
    probe some.hierarchical.path. -all -memories -depth all
    the above command will problem all signals within the some.hiearchical.path instance and below, including memories.
    If you re using $shm_probe within verilog code, add "M" as an option, eg.
    $shm_probe ("some.hierarchical.path", "ASM");
    The above shm_probe will probe all signals within the specified scope and below, excluding library cells, and will also include memories.
     Hope that helps.
    Mickey
  • Mickey
    Hi Paul,
     I just realized that I didn't answer your second question about memory preload.  You can preload memories using a tcl command.
     For more information take a look at the memory command in the tcl command reference within the IES installation (<ies_install>/tools/doc/tclcmdref/tclcmdref.pdf).
     Best regards,
    Mickey
  • PAULKI
    Hi Mickey,
    Thanks for your quick reply.
    If you can share some example code of tcl file and pre-load tcl file much appreciated.
    Paul
