  2. Functional Verification
  3. I need a PSPICE model for a Litium Ion battery - 8s32p
  • Subscribers 66
  • Views 2669
archive over 14 years ago
 I have the indivial cell discharge characteristics over different temp and different frequencies. How do i model this battery in PSPICE?
Please help.
thanks
-Anu-
  • Alok Tripathi
    Alok Tripathi over 14 years ago
    You can use behavior model techniques to describe the cell discharge behavior. One typical way is to make a controlled source, where input-output relationship is defined using a polynomial. The polynomial coefficients are needs to be extracted from the discharge characteristics. You can also try using the generic battery model supplied with cadence installation. This model name is “FLOODED_CELL”
