  2. Functional Verification
  3. Sequences from within other sequences of different type
  • Subscribers 67
  • Views 14236
hailesen
hailesen over 14 years ago
      I was wondering if there was a way in Specman to start a sequence from within another sequence with a differentsequence driver type? I tried passing in the other driver as a pointer but I get the error message below.
   *** Error: top_mempage_pin_seq is of type: TOP_MEMPAGE_PIN_SEQ'kind seq_s
                sequence: CFG_MEMPAGE_SWAP_SEQ'kind vr_ad_sequence can only do sequences of type: vr_ad_sequence or items of type: vr_ad_operation
                                at line 95 in /proj/digi120/devel/hailesen/dcs_tb/tbc/ip/e/seq_lib/cfg_mempage_swap_seq.e
            do top_mempage_pin_seq keeping {
SH
  • danielpoe2
    danielpoe2 over 14 years ago
     Sure,
    what you have to do is to constrain the "driver" of the sequence. For virtual sequence drivers you'll always have to do this:
    extend MY vr_ad_sequence {
       !mpage_seq : TOP_MEMPAGE_PIN_SEQ seq_s;
       body()@driver.clock is only {
          do mpage_seq keeping {
             .driver = <specman-path-to-driver>;
             -- other constraints ...
    NOTE: that I wouldn't consider it good style to call a foreign sequence in a vr_ad_sequence. You rather create your virtual sequence driver and from there you execute the vr_ad_seqeunce and the seq_s sequence. See "5.5 Using Virtual Sequences" in "Creating e testbenches" guide (or start "cdnshelp" and search for "virtual sequences").
     Cheers,
    Dainel
  • hailesen
    Thanks Daniel. I actually was using starting both sequences from a virtual sequence and I just wanted to know if it was possible to do it within a non-virtual sequence driver. There are a few cases where it would be useful :)
    SH
