  2. Functional Verification
  3. Exclude functional coverage for particular test
  • Subscribers 66
  • Views 16120
Ravisinha
Ravisinha over 14 years ago
Hi All, I am running regression for my SOC and that list contains the register write-read test also, and because of that my vr_ad functional coverage is 100%. Is that any way/switch by which for register write-read testcase i can disable collecting the functional coverage in SPECMAN. Thanks in advance.
  • StephenH
    StephenH over 14 years ago
    An excellent question, as this highlights the danger of relying on automatic coverage.
    In vr_ad you can constrain the has_coverage field of your vr_ad_map or vr_ad_reg_file. By default it's TRUE, but if you constrain it to FALSE then you won't get any coverage collected. So, in your test file you can do something like:
    extend my_env {
      keep not my_map.has_coverage;
    The nice thing about this is that has_coverage simply disables the emission of the coverage event, so it doesn't change the coverage model itself. This means all your tests can be merged without conflict.
  • Ravisinha
    Hi Stephen, Thanks for ur help, In my verification environment vr_ad is getting loaded at last so i was not able to do the above line of code because till that time my_env was no such feild("reg_mem.addr_maps") so what i did is, i extended vr_ad_group and did that. extend vr_ad_group{ keep soft has_coverage == FALSE; };
  • StephenH
     Surely your test file would be the last one loaded, so you could have put the extend in there?
  • Ravisinha
    Yes that's true but the problem here was I was using the legacy code of my client and in the testcase only they are calling the setup file in which vr_ad is also getting compiled.
  • StephenH
    This should not cause a problem. For example:
    // test.e
    import my_env_config;
    extend my_env {
      keep not mem_map.has_coverage;
    If you're still having difficulty, please can you file a service request on http://support.cadence.com/ so we can organise some more appropriate support?
