  2. Functional Verification
  3. urgent :: problem in sv-vhdl bind
  • Subscribers 66
  • Views 13813
Sudheer59
Sudheer59 over 14 years ago
I am using bind construct to capture internal signals(from vhdl entity ) to SV testbench.
During simulation how i can give this bind text file to irun command.
 i am using -exbind <filename>, but still i am getting issue with the instance.
"Hierarchical name component lookup failed at "
 In which phase i need to give this command. how i know it is binded correctly from my log
    archive over 14 years ago
    The correct syntax is "ncelab -extbind myBindFile".
    If that's not it, please post the contents of the bind file and show the hierarchy of where you are trying to bind to.
