  2. Functional Verification
  3. Issues in merging coverage using iccr
  • Subscribers 66
  • Views 13940
Oragniz
Oragniz over 14 years ago
Hi All,
        I would first like to bring to your notice that i'm very new to iccr. I face problem in merging coverage data from two rtl releases.
        On the first, i'm not sure whether i can merge data from two different rtl releases. If possible, then i've issue in doing so..
        The error message that it's showing is:
         iccr "Library name of this test does not match that of primary test. To merge tests where the same code is compiled into different libraries, elaborate with CCF command "set_ignore_library_name" and then resimulate. This will allow merge of data."
        I even tried setting  set_ignore_library_name option in my compile script and then resimulated and again tried to merge, but, stil i face the same issue..
      Can anyone please help me resolve this issue.
  • pcarzola
    pcarzola over 13 years ago
    set_ignore_library_name should work.  Try and compile into the same library and see if that works.
    If you still have issues, please file a support ticket
