  2. Functional Verification
  3. behavior of disabling constraint_mode from subclass
  • Subscribers 66
  • Views 13083
xbluewings
xbluewings over 14 years ago
Hello experts,
we found some inconsistent behavior between qsim and ncsim when trying to enable/disable constraint_mode from subclass. Here is the code sample:
class cls;
    rand int a;
    rand int b;
    rand int c;
    constraint c_a {a == -1;}
    constraint c_b {b == -1;}
    constraint c_c {c == 1;}
    function new();
    endfunction
    virtual function void do_rand();
      $display("Before randomize ...");
      $display("  a = %0d", a);
      $display("  b = %0d", b);
      $display("  c = %0d", c);
      this.constraint_mode(0);   //how many constraint blocks are disable? cls::c_a, cls::c_b, cls::c_c,  cls_e::c_a, cls_e::c_b
      this.c_a.constraint_mode(1); // which is enabled?
      this.c_b.constraint_mode(1); // which is enabled?
      assert(this.randomize(a,b) with {1;});
      this.constraint_mode(1);
      $display("After randomize ...");
    endfunction
endclass
class cls_e extends cls;
    constraint c_a { a==8000; }
    constraint c_b { b==40; }
endclass
module test();
    cls_e cls_inst;
    initial begin
      cls_inst = new;
      cls_inst.do_rand();
    end
endmodule
In qsim, cls_e::c_a and cls_e::c_b are working; but not in ncsim...
Is the behavior of the above three "constraint_mode()" statements clearly defined in spec?
-Xiaofei
