  2. Functional Verification
  3. one answer plz
  • Subscribers 66
  • Views 13522
one answer plz
redrabbit
redrabbit over 14 years ago
hi all,
i write one constraints embedded two foreach loop in it,find something i could not control.....
code:
gen cur_random_interval keeping
    it.size() == xxxxxx;
    for each (p) using index (idx) in it
        xxxxxxxxxxx;
        for each (q) using prev(prev_item) in p.rdata_dv_interval_location
              q < = (cur_list[idx].e_size[cur_list[idx].cb_idx]/16 - 1);
              index == 0 => q==1;
              q > 0;
             soft q > prev_item;
 the structure is like "list of list",in the inner loop, i want to constraint prev_item is smaller it's next. then to generate one list,but i message the list which items in are generated wrapped,,,like   1  3   6    9 ... 2    4  6  8.... 2   5   8  .....   ,but i want the result to be like  1 2 3 4 5 6 7  8 9 .....
and i could not remove the word soft ,    or will cause an syntax error.
 what should i do?
  • hannes
    hannes over 14 years ago
     Hello redrabbit,
    the code you have above seems to work ok for me. Maybe there are some other pieces of code
    which might cause your issue. I think it would be helpful to get in touch with support with a more
    detailed testcase, or the log file
    Best regrads,
    -hannes
