  2. Functional Verification
  3. one question about e hal --ignore or delete the post pl...
  • Subscribers 66
  • Views 1323
one question about e hal --ignore or delete the post plz
redrabbit
redrabbit over 13 years ago
hi all,
       the verification enviroment has complete and i created the senarios which i could figure out,now i want to check my code style or something with the cadence tool---hal.
       it help me a lot ,but there is one error makes my so confused.
    EAVDNA: Variable xxx is declared, and is written in  at xxx line in yyy.e file but not read.
here is one example in ehal.pdf
In the following example, var g is written, but not read:
struct bar_s {
a : int;
foo() is {
var g : int ;
g = a;
In the following example, var g is both read and written:
struct bar_s {
a : int;
b : int;
foo() is {
var g : int ;
g = a;
b = g;
i want to ask why??the problem is so usual in my code ,what is the risk?
thank you in advance.
redrabbit.
  • redrabbit
    i found one  intention of this rule is to help the usr find the variables defined but not use it properly, delete the redundancy.....
    am i right?
  • StephenH
    StephenH over 13 years ago
    This is a rule that exists in many other languages. I think you'll see it in GNU C/C++ compilers for example. The risks are that you made a typo and assigned to or read from the wrong variable; that you declared a variable with the wrong name; that you forgot to implement part of your code; you're storing something for debug and consequently wasting memory... Like with most linting, the tool can't tell you what you did wrong, it doesn't understand your intent. What it can do is draw your attention to places where there might be bugs or functional / performance problems.
  • redrabbit
    thank you StephenH!
