  2. Functional Verification
  3. Regarding the support for INCISIV10.20.25
  • Subscribers 66
  • Views 13569
anubhaw2004
anubhaw2004 over 13 years ago
 Hi ,
     I am using NCSIM ver 10.20.  In my bfm we have implemented the wrapper in SV as the actual bfm is in
     C++(SV DPI). Similarly we have also implemented the callback in the bfm and the wrapper . When i am writting the coverage in
    UVM  and using the callback that were basically impleneted in c++ and in SV by using the DPI concept of the SV, its not working.
     Same code is working very fine with Questa and VCS. Do i need to add some code in my script to use the callback in my
     UVM monitor. Can anyone help me in this.
Anu
  • StephenH
    StephenH over 13 years ago
    Hello Anu.
    I can't think of any reason why your code wouldn't work. We'll likely need to have a closer look at the problem and see you source code to understand exactly what you are doing. Rather than doing that in a public forum where you probably can't share your code, please could you file a support request at http://support.cadence.com/ and we can then work with you to resolve the issue.
    By the way, 10.20.025 is already a bit dated; if you could try a newer version it might help. The very latest is 10.20.039 (for the 10.2 stream) or 11.10.007 for the 11.1 stream.
    Steve.
