  2. Functional Verification
  3. propagating data when generating VE
  • Subscribers 65
  • Views 13826
yongchen
yongchen over 13 years ago
I was confused when progapating data to generate VE by using "connect_pointers()" and "keep upper.comp = read_only(comp)".
1) When should I use "connect_pointers" and when should I use "keep ... read_only"? For example, xserial example from Incisive gives an example as this:
extend ACTIVE has_tx_path xserial_agent_u {
   tx_bfm: xserial_bfm_u is instance;
      keep tx_bfm.driver == read_only(tx_driver);
      connect_pointers() is also {
          tx_bfm.agent = me;
2) In document from Invisiv 11.1, "Specman IntelliGen User Guide", 3-9, there is an example to show connect_pointers() as:
extend agent {
   bfm: ex_atm_bfm is instance;
  driver: ex_atm_sequence_driver is instance;
    bfm.driver = driver;
    driver.bfm = bfm;
My question is : why there is no "!" before driver/bfm? In what case should I add this "!" to unit?
thanks
  • StephenH
    StephenH over 13 years ago
    Hello Yongchen.
    In general you would use constraints to connect unit pointers. The connect_pointers() method is provided so that you can avoid deep hierarchical constraints when hooking up TLM ports, monitors to scoreboards etc. For example your bus monitor might have a pointer to a scoreboard "!p_scbd : my_scoreboard". You can then hook that procedurally via connect_pointers() from the top-level: "tb_top.axi_env.monitor = tb_top.scbd". Sometimes it's just easier this way than using constriants. There's no hard rule, so it's up to you to judge what is best.
    You would use the "!" (do-not-generate) attribute on a unit if it's meant to serve as a pointer and will be connected procedurally via connect_pointers(). Without the "!" a unit declaration MUST be either declared "is instance" or constrained to point to a real instance via a keep constraint. The "is instance" tells the generator that this object is a real unit, not a pointer to a unit.
    Hope this helps.
    Steve.
  • yongchen
    Thanks Steve. It is very helpful.
    Yong Chen
