  2. Functional Verification
  3. System Verilog and AMS
  • Subscribers 66
  • Views 15416
Anky
Anky over 13 years ago
Hi All,
Which tool is supporting system verilog and ams both togather?
I am using IUS 10.20-s106 and getting error as below:
ncvlog: *F,AMSASV: The -ams and -sv options cannot be used together.
 Please help me out.
Ankit
  • tpylant
    tpylant over 13 years ago
    By using the “-sv” switch, you are turning on the SV compiler for ALL files. By using the “-ams” switch, you are turning on the AMS compiler for ALL files. Since AMS does not support SV, this is a conflict.
    The best way to use the “irun” command is to take advantage of automatic compiler selection by file name extension. You would name all your SV files with a “.sv” filename extension and all the Verilog AMS files with “.vams” extension. You would not need to specify the “-sv” or “-ams” switch and irun would pick the compiler based on the extension.
    If you don’t want to rename the filename extensions, you would need to run “irun –compile –ams” on just the Verilog AMS files and then run “irun –compile –sv” on just the SV files. Then you can run “irun –c” and “irun –R” to elaborate and simulate.
    Tim
