  2. Functional Verification
  3. forcing the creation of a vcd file
  • Replies 14
  • Subscribers 69
  • Views 40366
freitas
freitas over 14 years ago
How do I instruct simvision to force the creation of a vcd file?
I am trying to create tcl script to dump signals into a vcd file and then immediately post-process this very vcd.
These are the two lines I want to run in sequence from a ncsim tcl script :
simvision -submit "database export $my_signals -format vcd -name my_vcd.vcd"
file copy my_vcd.vcd ${my_dir}/myvcd.vcd
The problem that I am experiencing is that simvision seems to postpone the creation of the vcd file. Therefore, at the moment the second line is executed the vcd file is not yet available.
I get the following error:
ncsim> *E,TCLERR: error copying "driver.vcd": no such file or directory
However, if I run the two lines separately (i.e., not in a script) it works.So It seems that I have to force the creation of the vcd, but I don't know how.
I would appreciate your help.
Thanks!
  • StephenH
    StephenH over 5 years ago in reply to rkaur9 +1
    These would be variables that you've set in Tcl, if you don't set them, the tool can't read them!
  • StephenH
    ncsim> database -open my_vcd -vcd -into myvcd.vcd ncsim> probe -create -database my_vcd [scope -tops] -depth all -all login to https://support.cadence.com/ and search for the "probe command syntax…
  • StephenH
  • rkaur9
    rkaur9 over 5 years ago in reply to StephenH
    Thanks for your response, i am trying to create vcd dump file and i have testbench.sv as top file
    how can i use it without setting variables
    tried this one also
    ncsim> probe -create -database my_vcd  testbench/*
    thnks
  • StephenH
    login to https://support.cadence.com/ and search for the "probe command syntax" for full details and examples.
  • rkaur9
    Hi Stephen,
     Thanks a lot for the information, that works,
    thanks
