  2. Functional Verification
  3. Loading Coverage Databases
  • Subscribers 66
  • Views 16761
jijops
jijops over 13 years ago
I am facing some issues while trying to merge coverage data from two tests with different ucd and ucm file names.
The test names are test_1(icc_000.ucm, ic_000.ucd) and test_2(icc_001.ucm, icc_001.ucd).
The execution of command load_test with argument test_* gives me the following error message:
"Loading of coverage data ../icc_001.ucd failed due to mismatch in checksum with the loaded model file ../icc_000.ucm"
Can someone help?
Thanks in advance,
Jijo
  • pcarzola
    pcarzola over 13 years ago
    Hello Jijo,
    For merging using ICCR using load_test is not the right approach.  Instead use merge <first_test> <second_test> .
    You should also take a look at IMC which has a similar use model.  Please refer to the ICC User guide or IMC User's guide for guidance on merging.
    -Paul
