  2. Functional Verification
  3. How to filter X -> 0 or X -> 1 from signals for events
  • Subscribers 66
  • Views 1571
jaichandra
jaichandra over 13 years ago
Hi all,
          I am having problem in filtering the changes from x->1 and x->0 on a singal which i use to generate events.
       For example,
            I have a simple port "a" of type in, which is connected to a DUT signal. DUT drives x on the signal "a" for some time initially
 (10ns)   and then drives the value 1. I declared an event as shown below. clk_r is a clock rising event. The first clk_r event is available
  well after signal "a" settles with the value 1.
      event a_e is rise(a$)@clk_r;
   Because of the change from x->1 on the signal "a", i receive an event on a_e on the first clk_r event.
   Can anyone suggest me how i can filter this unwanted event.
  • MDK1234
    MDK1234 over 13 years ago
    By default, ICC records transitions 1 -> 0 and 0 -> 1. To record transitions X -> 0 and
    X -> 1, use the set_toggle_includex command.
    Consider transition 0 -> X -> 1 -> 0 -> X -> 1.
    In the absence of the set_toggle_includex command,
    ■ The number of rise transitions is 0.
    ■ The number of fall transitions is 1 (1 -> 0).
    With this command,
    ■ The number of rise transitions is 2 (X -> 1 and X -> 1).
  • jaichandra
    Hi MDK1234,
             Thanks for your reply. I created a work around for my issue by using the reset signal and ignoring the initial transitions from x->1 by checking if the reset is true.
       Thanks again for your reply.
  • hannes
    hannes over 13 years ago
    Hello Jaichandra,
    you can also use an event port and multi-value logic (MVL), which can distinguish between U, Z, X, 0 and 1:
    sd_rise : in event_port is instance;
       keep sd_rise.hdl_path() == “whatever you have for the other port”;
       keep sd_rise.edge() == MVL_0_TO_1;
    -hannes
