  2. Functional Verification
  3. "INTERNAL EXCEPTION" when ncsim
  • Subscribers 66
  • Views 3300
Tommy zou
Tommy zou over 13 years ago
Hi all,
  When I run a project using ncsim, and find the fatal error, which is list as below, I want to know how can I detect the error more deeper.
INTERNAL EXCEPTION
Observed simulation time : 0 FS + 0
The tool has encountered an unexpected condition and must exit.
Contact Cadence Design Systems customer support about this
problem and provide enough information to help us reproduce it,
including the logfile that contains this error message.
  TOOL: ncsim 12.10-s003
HOSTNAME: sh-c-11.hongkong.cortina.local
OPERATING SYSTEM: Linux 2.6.18-238.5.1.el5 #1 SMP Fri Apr 1 18:41:58 EDT 2011 x86_64
MESSAGE: missing unilang library
csi-ncsim - CSI: Cadence Support Investigation, recording details
Code Item: ra (COD_RA)
Intermediate File: root (IF_ROOT)
Verilog Syntax Tree: overlay table (VST_OVERLAY_TABLE) in verilog_package worklib.cvm_pkg:sv (SIG) <0x65123be8>
Decompile: cvm_pkg::cvm_vdb
Code Item: stream (COD_STREAM)
Decompile: cvm_pkg::cvm_component
Simulator Snap Shot: gd (SSS_GD) in snapshot worklib.ilkn_if:sv (SSS)
Simulator Snap Shot: dynlib (SSS_DYNLIB) in snapshot worklib.ilkn_if:sv (SSS)
Intermediate File: string (IF_STRING) in verilog_package worklib.cvm_pkg:sv (VST)
 Decompile: vmm_str_match
Simulator
Snap Shot: dynpatch (SSS_DYNPATCH) in snapshot worklib.ilkn_if:sv (SSS)
Intermediate File: string (IF_STRING) in snapshot worklib.ilkn_if:sv (SSS)
 Decompile: /auto/tools/cadence/simulation/INCISIV12.10.003/tools/uvm/uvm_lib/uvm_sv/lib/libuvmpli.so
Simulator Snap Shot: root (SSS_ROOT) in snapshot worklib.ilkn_if:sv (SSS)
Internal Code in function: ncmain offset 43
User Code in function: main offset 27
User Code in function: __libc_start_main offset 220
csi-ncsim - CSI: investigation complete took 0.071 secs, send this file to Cadence Support
  Feng
