  2. Functional Verification
  3. Looking for help with System Verilog in AMS
  • Replies 12
  • Subscribers 67
  • Views 23255
JRAHildebrand
JRAHildebrand over 14 years ago
I've generated a netlist for a testcase and get the following error in the irun.log:
Elaborating the design hierarchy:
bias i_bias ( .ibias(ibias[3:0]), .vdd(vdd), .vss(vss), .en(en[0]));
ncelab: *E,CUINFI (./netlist.vams,39|41): An interface declaration must be connected to an interface (test_top.i_top).
   Analog vdd, vss;
ncelab: *E,CUIMBC (./development/SYS_VLOG_ANA_TEST/bias_verilog.sv,42|12): An interface port declaration must be connected (test_top.i_top.i_bias).
ncelab: *E,CUINFI (./netlist.vams,39|52): An interface declaration must be connected to an interface (test_top.i_top).
   Analog vdd, vss;
ncelab: *E,CUIMBC (./development/SYS_VLOG_ANA_TEST/bias_verilog.sv,42|17): An interface port declaration must be connected (test_top.i_top.i_bias).
That goes on for a while and there are a number of them.  So, the question is how do I connect the port declaration?  Here's the file referenced:
 import ADMS_signals_pkg::*;
module bias (
              vdd,
              vss,
              en,
              ibias
`include "parameters.svh"
   Analog vdd, vss;
   Analog ibias[3:0];
   input wire en;
   Amps                 iout[3:0];
   integer              vdd_ok;
   integer              vss_ok;
   integer              supplies_ok;
   event                started;
//   Driver vdd_d         = new(vdd);
//   Driver vss_d         = new(vss);
   ISource ibias_src[3:0];
   initial begin
      foreach (ibias_src[i])
        begin
           ibias_src[i]=new(ibias[i]);
        end
      @(en == 1'b1 && supplies_ok == TRUE);
      #100 -> started;
   end
//   Driver ibias_d = new(ibias[1]);
//   Driver ibias_d = new(ibias[2]);
//   Driver ibias_d = new(ibias[3]);
   always @(vdd.changed)
     begin
        if (vdd.v < VDD_MIN)
          vdd_ok = FALSE;
        else if (vdd.v > VDD_MAX)
          vdd_ok = FALSE;
        else
          vdd_ok = TRUE;
     end
   always @(vss.changed)
     begin
        if (vss.v < VSS_MIN)
          vss_ok = FALSE;
        else if (vss.v > VSS_MAX)
          vss_ok = FALSE;
        else
          vss_ok = TRUE;
     end
   always @(vdd_ok, vss_ok)
     begin
        if (vdd_ok == TRUE && vss_ok == TRUE)
          supplies_ok = TRUE;
        else
          supplies_ok = FALSE;
     end
   initial iout[0] = -IBIAS_TYP;
   initial iout[1] = -IBIAS_TYP;
   initial iout[2] = -IBIAS_TYP;
   initial iout[3] = -IBIAS_TYP;
   always @(started,en)
     begin
          if ( en==1'b1 && supplies_ok==TRUE)
            ibias_src[i].seti(iout[i]);
          else
            ibias_src[i].seti(0.0);
     end
endmodule // bias
  • JRAHildebrand
    Shalom: Would it be ok if I sent you email with the files directly?  I don't see any way to attach files to a message in the forum.
    Jeff
  • Shalom B
    Shalom B over 14 years ago
    Sure.
    shalom.bresticker@intel.com
