  2. Functional Verification
  3. Concatenating enumerated types in coverpoint
  • Subscribers 66
  • Views 16607
RajeshCM
RajeshCM over 13 years ago
I will explain my query with an example.
AddrHigh is a 16-bit address which is enumerated as NORMAL, DEVICE etc.. AddrLow is also a 16-bit address which is enumerated as TIMER, UART etc..
 I want to concatenate AddrLow and AddrHigh, and declare bins like below. I don't want to specify binary values instead I want specify bins using enumerated names. Is it possible? If yes, what is the syntax?
 a: coverpoint {AddHigh, AddrLow} {
       //bins
  • tpylant
    tpylant over 13 years ago
    Yes, you can do this. Your syntax was correct:
    covergroup ….
      A : coverpoint {AddrHigh, AddrLow} {
        bins HI[: {NORMAL, DEVICE, …};
        bins LO[: {TIMER, UART, …};
    endgroup
    Tim
  • tpylant
    My text got screwed up below. Let me try again:
    covergroup ….
        bins HI[ = {NORMAL, DEVICE, …};
        bins LO[ = {TIMER, UART, …};
    endgroup
    Tim
  • RajeshCM
     We use comma separated values with in curly braces if we want to assign more than one value to a bin. For example,
           bin Index = {0x0, 0x1, 0x2};
     But my requirement is to concatenate enumerated types. The syntax you specified appears to be same as above except for a "[" after the bin name. So square bracket syntax differentiates between the two?
  • tpylant
    The square brackets (which refused  to cooperate) are optional. They are for "vector" bins which keep track of each value in the bin individually. Your example worked with either syntax.
    Tim
