  2. Functional Verification
  3. VCS to IRUN Conversion Error, UVM-1.1 System Verilog
  • Subscribers 66
  • Views 15803
Maisum
Maisum over 12 years ago
   I am using INCISIV 11.1 to compile a project which works perfectly on VCS, However I get the following errors on cadence using the irun command .
ncvlog: *E, CLSSLV Class reference illegal in this reference on line :
 data_in[0] <= link_if.cbd.link_tx_serdes_data_0
and ncvlog: *E, DYNNBA Reference to whole or element of dynamic array/fixed array of dynamic array are illegal in this context
data_in is declared as a protected logic [`OSI_WD_WIDTH-1:0] data_in [ ] and initialized to size 16.  link_tx_serdes_data_0 is declared as logic [`OSI_SERDES_WIDTH-1:0] in an interface. link_tx_serdes_data_0 is declared as an input in clocking block cbd.
The data_in is also registered as a uvm_component:
`uvm_field_array_int(data_in,UVM_ALL_ON)
All required files have been compiled prior to compiling this file. And the whole project works perfectly on VCS.
Maisum.
  • StephenH
    StephenH over 12 years ago
    Non-blocking assignments to class members aren't legal in SV. It works fine if you use blocking assignments:
     data_in[0] = link_if.cbd.link_tx_serdes_data_0;
  • Maisum
    Worked like a charm. Don't know why it was being accepted in VCS.
    Thanks.
