  2. Functional Verification
  3. re : parameterized sequences & property blocks in simvi...
  • Subscribers 67
  • Views 1982
re : parameterized sequences & property blocks in simvision
Srikanth Madam
Srikanth Madam over 12 years ago
HI,
    I have a strange problem with my simvision (version 11.10.-s66) that i have  written 2 assertions
      1) with parameterized sequnces and property
      2) normal assertion
     for some logic which you can find in the below code , but in the simvision the assertions finished at different timings , the one parameterized finished one clock pulse later than expected and the normal assertion finished properly. So can any one tell me whether it is tool issue ???
initial
begin
    clk = 1'b0; in1 = 4'd0; flag = 1'b0; out1 = 4'd0;
    repeat(2) @(negedge clk); in1 = 3'd2; flag = 1'b1;
    repeat(1) @(negedge clk); flag = 1'b0; out1 = 3'd3;
    repeat(5) @(negedge clk); $finish;
end
property p1;
    @(posedge clk)
        ( (in1 == 3'd2) && $rose(flag) ##1 $fell(flag)) |-> (out1 == 3'd3);
endproperty
    chk1 : assert property(p1) $display("Working Good");
            else $display("Not Working");
sequence s1(a);
    $rose(a) ##1 $fell(a);
endsequence
property p2(a1,b,c);
    @(posedge clk)
    ( (b == 3'd2) and s1(a1)) |-> ( c == 3'd3 ) ;
endproperty
    chk2 : assert property(p2(flag,in1,out1)) $display("Working Good");
Find the attachment for the picture containing assertions in the simvision
  • whiteriver1
    whiteriver1 over 12 years ago
    I could reproduce the exact same behavior here. Based on the documentation I have, your two properties should behave as property p1. But by replacing p2 with the code below, they both behave the same:
    sequence s1(a,b);
        (b == 3'd2) && $rose(a) ##1 $fell(a);
    endsequence
        @(posedge clk)
        s1(a1,b) |-> ( c == 3'd3 ) ;
    endproperty
  • Srikanth Madam
     Hi Whiteriver1,
         Thanks for the reply , but i just want to know is anything wrong with my code.
         I tried as you suggested it is working same as p1.
    Srikanth
