  2. Functional Verification
  3. Issue in merging two coverage runs with different checksums...
  • Subscribers 66
  • Views 15301
Issue in merging two coverage runs with different checksums in IMC.
Clair
Clair over 12 years ago
Hi all,
     I am trying to merge two different coverage runs with different checksum. It is not getting merged. I am getting messages like below.
    Block coverage not merged - Checksum differs.
    Expression coverage not merged - Checksum differs.
    Instance not found in the target model. Use the "merge_config" command (prior to the "merge" command) to map the source instance/type to the target instance/type
Is it possible to merge coverage runs with different checksums. Please let me how to merge the coverage in this case.
Thanks in advance,
Clair..
