  2. Functional Verification
  3. Specman error while running ENET VIP
  • Subscribers 66
  • Views 14955
navi2582
navi2582 over 12 years ago
I am getting the following specman related error. Modified the $PATH variable accordingly but of no use.
Any ideas from anyone?
Naveen
Here is the run.log file:
SEED=30561
Copying /MENTOR/install/modelsim_se_10.0c_2011_08/modeltech/linux/../modelsim.ini to modelsim.ini
Modifying modelsim.ini
Reading /MENTOR/install/modelsim_se_10.0c_2011_08/modeltech/tcl/vsim/pref.tcl
# 10.0c
# vsim +OVM_TESTNAME=test +define+QUESTA +MSEQ_COUNT=2 +define+ENET_TENGKR -do {coverage save -onexit ./cov/test.ucdb;do /xx/xx/waves_full.do; sn test; set SolveArrayResizeMax 10000; run -all; exit} -dpioutoftheblue 1 -gblso /CADENCE/VIPCAT11.30.013_OVM/tools.lnx86/denali_64bit/libmtipli.so -l ./logs/test.log -c -pli /CADENCE/VIPCAT11.30.013_OVM/tools.lnx86/denali_64bit/libmtipli.so -pli /CADENCE/VIPCAT11.30.013_OVM/tools.lnx86/specman/lib/64bit/libmti_sv_sn_boot.so -suppress 3009 -t 1ps -novopt -sv_lib /CADENCE/VIPCAT11.30.013_OVM/tools.lnx86/specman/lib/64bit/libmti_sv_sn_boot -sv_lib /xx/xx/denaliEnetSvIf specman specman_wave top_level_top
*** Error: Specman is unable to execute sn_root. Add <Specman installation directory>/bin to the beginning of your PATH.
# Loading /var/tmp/xxx_dpi_28019/linux_x86_64_gcc-4.1.2/export_tramp.so
# Loading /CADENCE/VIPCAT11.30.013_OVM/tools.lnx86/denali_64bit/libmtipli.so
# Loading /CADENCE/VIPCAT11.30.013_OVM/tools.lnx86/specman/lib/64bit/libmti_sv_sn_boot.so
  • Avi Farjoun
    Avi Farjoun over 12 years ago
    Try putting <VIP_INSTALL>/tools/bin in the PATH
