  2. Functional Verification
  3. Slow simulation caused by Assertions
  • Subscribers 66
  • Views 16963
nwang
nwang over 12 years ago
I am using -profile to investigate why my simulation is so slow, and I found the warning:
ncsim: *W,FLSTRT
the explanation of it is: The assertion is spending a significant amount of time starting new
        attempts that immediately terminate.  In most assertions, such activity
        can be minimized by optimizations in ncsim; something about this
        assertion is preventing those optimizations from taking effect.
I want to know what prevent the optimization, how can I fix it?
 My assertion is fairly simple as below:
 property check_conflict;
      @(posedge clk) ((a && b && !c) ##1 (d && c)) |-> ##[0:2]  S;
   endproperty
   conflict:assert property (disable iff (!rst_an) check_conflict)
         else `uvm_error("ERROR",$psprintf("conflict at %0t \n",$time))
Further, I don't quite understand what it means in the warning explaination "starting new attempts". In the case of my assertion, does it mean new attempts are started by satifying the first part of the expression (a && b && !c) is true, but terminated by (d&&c) is not true after ##1?  From what I see in the waveform, my undertanding is not right. Can someone explain?
 Could anyone help? Really appreciated.
  • tpylant
    tpylant over 12 years ago
    You should check out the Coding Style Guidelines for Maximizing Assertion Performance guide. You can find it by launching 'cdnshelp' and going to Incisive Enterprise Simulator -> Assertion-Based Verification -> Assertion Writing Guide -> Maximizing Assertion Performance.
    Tim
  • nwang
     Thank you very much, Tim.
    That's the document I need to study.
  • nwang
     Hi Tim,
    I have a further question.
    In the report ncprof.out, I have over 20% Stream Counts hits on SSS_MT_SVHASSIGN method, is it normal ?
    And over 60% on a function which is checking memory data. Although the test case is doing a lot of memory read/write continuously, does this high percetage look OK?
    Thank you.
  • tpylant
    These method entries are optimized assembly routines which are mostly event simulator internal operations. I would suggest trying the "-iprof" option that provide more detail than the standard "-profile" option. you'll need to use the "iprof" command to analyze the output from "-iprof". It is best to review the iprof help by searching for iprof in cdsnhelp.
     Tim
