  2. Functional Verification
  3. ncsim -out directive
  • Subscribers 66
  • Views 1099
affaqq
affaqq over 12 years ago
I created a sub-directory inside the main directory where I am invoking Incisive to dump all the files generated using "-out" argument. In my design, I need to pick values from a certain file from the main directory. Now the ncsim looks for that file into the sub-directory I have created and obviously its not there. Is there any way to specify such argument in the Makefile attached alongwith?
  • Makefile.txt
  • tpylant
    tpylant over 12 years ago
    The "-out" option has been deprecated in the latest releases. You should be using the "-log" option with the latest releases.
     The "-log" option allows you to specify a full path for the logfile. So you should run from the main directory and point the logile to the sub-directory.
    Ex: ncsim test -log subdir/sim.log
    Tim
